Hello @josh
It is or will be possible to show power consumption info in switch tile, instead of ON/OFF ?
I mean:
Hello @josh
I mean:
@Dawid_F, you can enable the 2nd attribute display after change the tile layout to “Hero Attribute”. See the example below that it shows both switch status and the power consumption, and I can still tap it to turn the switch on/off.
Thanks @James
This is kind of solution, but you know… my idea is better ![]()
I very like feature with big, glowing icon.
I can’t find an option to turn on glowing in Hero Attribute tile.
