I seem to be having a problem when adding a new action into an existing “if” block. If I position the new action within the “then” or “else” flow, everything is fine; however, as soon as I save and reopen the rule, the new action changes places and moves to the bottom of the set of actions instead of remaining in its original position. Is there a workaround to stop this from happening?
Edit: I’ve resolved my issue by deleting the actions up to the point where the new action needed to be positioned and then recreating the deleted actions below it.
