Plex Webhook: Assign JSON payload events to variables
Hello. I’m having some trouble parsing a JSON payload and assigning variables to specific events. I followed the instructions here, but I’m stuck on how to actually retrieve the JSON data and assign it to variables.
I’m using Plex to send a webhook to the rule I’ve created in SharpTools.
I’ve set up a HTTP trigger and copied the URL into the webhook settings in Plex.
I have an action set up to assign a variable to a specific payload called ‘event’.
Set variable $event value using $context.event.params.event value
Plex seems to successfully trigger the rule according to the log, but I keep getting this error…
12:41:24 PM
Triggered by http event: API Key 353dddxxx-xxxx-xxxx-xxxx-xxxxxxce191e
12:41:24 PM
Set variable value: $event = undefined
The data is supposed to be ‘media.stop’ or ‘media.play’.
Any ideas what I’m doing wrong?
Can you PM me the Rule ID so I can take a closer look at the payload that’s being received?
The format $context.event.params.event would imply that the source is sending over a payload with an object that has an event property, is that right?
  "event":
        "foo": "bar"
or
  "event": "XXX",
  "foo": "bar"
That’s correct. There is a payload called ‘event’ that is supposed to be sending something like ‘media.stop’ or media.play’.
I will PM the Rule ID.
Forgive me I’m new here. How do I PM a message? I can’t seem to find it.
Normally you would tap my profile icon and then see a ‘Message’ button. As a new community member, you may not see that feature right away.
I was able to create a webhook using my Plex account, so I’m taking a look at it now. :slight_smile:
It looks like the Plex Webhook implementation is kind of quirky. Instead of sending the webhook over as a traditional webhook with JSON as the body, they’re using a special form encoding which is usually reserved for files and embedding the JSON within that.
Anyway, it’s an odd format, but we’ll take a look at extending the Rule HTTP Trigger to support it in a future update.
Ok thank you. Glad it wasn’t just me.
We pushed an update to support the weird Plex format. :slight_smile:
Wow! You’ve made my day.
It is working great now!
How did you get this working? I have a rule set up with a webhook and in the logs I can see the data is coming through to sharp tools but I have not idea how to use this data to trigger anything.
What I want to do is use the event media.play to trigger a scene in Smartthings
You can assign any parameters you want to context variables. In this case you want the “event” parameter.
Perfect, thank you very much
