Would it be possible to make the borders of some objects on a super tile visible? I am totally hooked on super tiles and often split the functions when it is pressed. For example on the super tile to switch a light, the top half of the tile will switch the light on or off, and the bottom half will step through the motion sensor options for the light. (Day and Night or just Night motion switch)
Here are screenshots of the Entrance light tile. Pressing on the top half will switch the light on and off.
In the design view the function split is done with the header label which triggers a separate rule. On the bottom left is a small slider icon, serving as a tip that there are multiple functions.
My request in this case is: Can the border for the label “Eingang” be made visible as an option?
@Stan_Silverman mentioned the idea of being able to draw vertical or horizontal lines in a different discussion, but I don’t think there was ever a feature request created for it.
It sounds like he uses a label tile with several underscores to create a horizontal line effect.
PS. Don’t forget to scroll up to the top of this topic and cast a vote on your own feature request!
