One rule to turn device on/off
I’d like to create a rule that turns on a smart plug in the morning at sunrise and then turns it off at 11:00 PM every day. Is that possible using only one rule instead of two? Thanks
You can do something like the following example. Use Sunrise and the time as the trigger and an IF condition in the follow to determine if it should be turning on or off the plug.
Thanks James! I’ll give this a try. Loving SharpTools.
