Hi @Douglas_Drake, can you try again without the IF_Condition in the flow? For this scenario, you only need the garage contact stats open for 5 minutes as trigger, and notification as the action in the flow. Although additional IF_Condition shouldn’t matter hear, but just wanted to simplified the rule setup. In the meantime, can you please open the garage for 5 minutes and let me know the rule ID (the last part of the URL when in that specific rule’s editor page)? With your permission, I’d be happy to look into the system log and investigate the cause.
Thanks for the updates. Changing the batter is definitely the 1st thing I’d suggest. The battery level is really just a reference and some sensors work fine with less than 40% battery level but some stop working when the battery is lower than 80%. It really just depends on the model and how the battery level is reported.
