News Ticker Tile (Custom Code)
Hey all, I’ve been messing with Claude (so AI disclaimer!) but I’ve managed to get a News Ticker tile going for Sharptools You may need to customise it with choice of feed. Add this as a custom tile under Developer Tools and let me know how you like it!
<!-- Do not edit below -->
<script type="application/json" id="tile-settings">
  "schema": "0.2.0",
  "settings": [],
  "name": "News Ticker",
  "dimensions": {"height": 1, "width": 4}
</script>
<!-- Do not edit above -->
<style>
  * { box-sizing: border-box; margin: 0; padding: 0; }
  body { background: transparent; overflow: hidden; height: 100%; display: flex; align-items: center; }
  .ticker-wrap {
    width: 100%;
    overflow: hidden;
    display: flex;
    height: 100%;
    position: relative;
  .ticker-track-wrap {
    flex: 1;
    overflow: hidden;
    position: relative;
    height: 100%;
    display: flex;
  .ticker-track {
    display: flex;
    white-space: nowrap;
    animation: ticker-scroll 120s linear infinite;
    will-change: transform;
  .ticker-track:hover { animation-play-state: paused; }
  @keyframes ticker-scroll {
    0%   { transform: translateX(0); }
    100% { transform: translateX(-50%); }
  .ticker-item {
    font-family: sans-serif;
    font-size: 22px;
    color: #ddd;
    padding: 0 24px;
  .ticker-item::before {
    content: '●';
    color: #c0392b;
    margin-right: 10px;
    font-size: 16px;
  .ticker-error {
    font-size: 22px;
    color: #888;
    padding: 0 16px;
</style>
<div class="ticker-wrap">
  <div class="ticker-track-wrap">
    <div class="ticker-track" id="ticker">
      <span class="ticker-error">Loading news...</span>
    </div>
  </div>
</div>
<script>
  var PROXY = 'https://api.rss2json.com/v1/api.json?rss_url=';
  var FEEDS = [
      url: 'https://www.newsnationnow.com/feed/',
      label: 'NewsNation',
      color: '#1a6bb5',
      max: 20
      url: 'https://baynews9.com/services/contentfeed.fl%7ctampa.hero.rss',
      label: 'Local News',
      color: '#c0392b',
      max: 20
      url: 'https://www.wtsp.com/feeds/syndication/rss/weather/forecast',
      label: '⛅ Weather',
      color: '#1a3a6b',
      max: 4
  async function loadFeed(feed) {
    try {
      var r = await fetch(PROXY + encodeURIComponent(feed.url));
      var d = await r.json();
      if (!d.items || d.items.length === 0) return [];
      return d.items.slice(0, feed.max).map(function(item) {
        return { title: item.title, label: feed.label, color: feed.color };
    } catch(e) {
      return [];
  async function loadAllFeeds() {
    var allItems = [];
    for (var i = 0; i < FEEDS.length; i++) {
      var items = await loadFeed(FEEDS[i]);
      allItems = allItems.concat(items);
    if (allItems.length === 0) {
      document.getElementById('ticker').innerHTML =
        '<span class="ticker-error">Unable to load news feeds</span>';
      return;
    var track = document.getElementById('ticker');
    var html = '';
    var doubled = allItems.concat(allItems);
    doubled.forEach(function(item) {
      html += '<span class="ticker-item">' +
        '<span style="background:' + item.color + ';color:#fff;font-size:14px;font-weight:700;letter-spacing:0.08em;text-transform:uppercase;padding:2px 8px;margin-right:10px;border-radius:2px;">' +
        item.label + '</span>' +
        item.title +
        '</span>';
    track.innerHTML = html;
    var totalWidth = track.scrollWidth;
    var duration = Math.max(40, totalWidth / 120);
    track.style.animationDuration = duration + 's';
  loadAllFeeds();
  setInterval(loadAllFeeds, 300000);
</script>
Hi there, I too have been using Claude AI Coder to make things for sharptools and my Hubitat hub. Good for you to make and share yours. I am still working out bugs in mine but will post mine soon too. Did you make any others yet?
A few others, problem seems to be that actiontiles isn’t talking to HASS directly so I have to use a webhooK and variables for anything that needs live device input.
Do you mean SharpTools and being able to access Home Assistant devices?
SharpTools has a Home Assistant Add-on, so if you have that setup and the HASS devices are authorized to SharpTools, your Custom Tile can directly access those Things including realtime state and sending commands.
:page_facing_up: Custom Tiles: Access to Things and Variables
Actually meant that all the attributes aren’t exposed to AT from HASS devices. Especially it seems through custom HTML
I’m happy to help if you want to share more details. There aren’t any artificial restrictions on which attributes are exposed. First step would be to make sure the states are available in Home Assistant and then that they are synced to SharpTools.
