I recently switched over from Vera to Smartthings and feel I have made a mistake. I haven’t been able to get any rule I’ve created here in SharpTools to work. Besides savings the rule after I’ve created it is there anything else I need to do?? This rule is simple, when my Samsung TV turns on it turns on my z-wave switch that powers my subwoofer. I also tried to set it up so it would send me a text message that the TV is on. All I’m trying to accomplish with my first rule is when the TV turns on the switch turns on and when the TV turns off the switch turns off.
I also tried using a Samsung Outlet and when I create a rule in SharpTools to turn the sub on when the power is at or above 50W it doesn’t work but when I do the same thing in Smartthings automations it works fine so it seems like SharpTools seems to be the issue.
Any thoughts are appreciated
