intent:#Intent;launchFlags=0x10000000;component=com.amazon.dee.app/com.amazon.dee.app.Launcher;end code I used for hyperlink to launch alexa and then click on play button at bottom which loads up music, going to try the music app though see if that makes it quicker. The advantage is you click on your music and it it asks what echo enabled devices to play it too.
Thanks Josh, Only just started down this rabbit hole after some email requests from readers asking if their was a simpler solution to home automation and displaying items on a wall mount that using some of the other solutions that dont involve a ton of coding knowledge.
Just in process of organising some kit to move forward with making this a even more in depth guide.
