Netamo weather station integration
Hi
When i add my netamo weather devices, i only get temperature values.
How do i get access to the humidity and other readings ?
It works in homey
You can add another copy of the Thing to your dashboard and change the layout to Hero Attribute and select your desired attribute:
Otherwise you could use a Super Tile to mix and match attributes from the same or different devices in whatever layout you’d like:
Thanks it worked :slight_smile:
Would you please list the Netatmo weather devices you are referring to?
