Is there any way for a button to have more than one event associated with it? I would like to have a button that I could swipe up to turn on all the living room lights; swipe down to turn off all the living room lights; and press to open a dashboard where I could turn them on or off individually. Single/double/triple taps would be OK also. Best I can tell, there is only one event and that’s “press.”
For standard tiles, the primary method of interaction is a tap and some tile types like Dimmers and Color Control support long-press interactions.
With Super Tiles, you can block off different parts of the tile to have different interactions. For example, this tile has four different icons and each has their own action:
Or this Super Tile for a window shade that supports separate actions for up/down/pause:
