Using SmartThings I have a Samsung multi sensor that grabs temp, contact, vibration, and location. Adding to my dashboard it’s only pulling the contact sensor and I really need the temp sensor. Anyway to get that working?
Hi @Chris_O_Quin, you can edit the tile and change the tile layout to Hero Attribute layout which allows you to customize what attribute(s) to be shown in the tile. See below for details.
Can you share the specifics on the multi sensor and location sharing?
That absolutely worked thanks so much!!
