I am not able to get any reaction from my hub when I change the mode via the dashboard. HSM works perfectly, but I have other rules tied to the mode. What am I missing?
Are you getting any error message?
I noticed you have a Hubitat and SmartThings location. Are you sure the mode is being changed on the right location?
Great point. Should I delete Smartthings if I no longer use it?
Yes, if you’re not using SmartThings anymore, you can remove it.
- Open your SharpTools.io User Page
- Tap the
...next to your SmartThings location - Scroll down and tap Disconnect
Perfect that works. Thank you!
