When constructing a rule which performs an action on a device you will be prompted for one or more arguments. When its a single argument that is usually pretty easy to guess, but when its two or three it gets more tricky. So my question is how does a user go about identifying the values and range of variables given device?
@Gary_Milne, the arguments shown in the action is based on how the command is defined in the device type handler (DTH). So depends on what device handler you are using, it may have different arguments. For example, in ST Z-Wave Lock DTH, setCode takes codeID, code, and codeName (optional) arguments. See below for ST Z-Wave Lock DTH where setCode() is defined.
As James mentioned, the device handler reports back the capabilities as well as custom commands and parameters that it supports. For custom commands, I’d usually recommend checking directly with the device handler developer in their respective community post or taking a look through their code.
Unfortunately, some device handlers don’t properly define commands and their parameters, but you can always manually change which parameters are sent (and in which order) using the ‘Advanced’ toggle in the top-right corner of the Device Action card.
