Is it possible to use a locally stored image as the dashboard background? Using a Fire HD 10. Been frustrated with google photos image being unable to connect after a 24 hr period (have been using the true image url – right click and image address)
Got it, thanks! So it has to be some sort of hyperlink even if it is “local”
Any idea how to solve the google photos problem? It works perfectly fine on PC Chrome browser, but the same dashboard on FKB on Fire HD 10, gives the “error loading image @&(&%(@#”
@Dev_SS, have you checked the thread below for using the image from Google Photo. I would guess the link you used previously was pointing to the image in the Google Photo “web page”, not to the image itself directly.
@James, thank you. I did go through that and the image (and dashboard) loads perfectly fine on Chrome on a PC. However, on FKB on HD 10, it gives that error. Has anything to do with the android web view issue with Fire OS?
