Is there a way to switch to a different dashboard in the rule engine or a workaround to accomplish this. I’m looking to have a certain dashboard come up when a virtual sw changes state. It’s like a warning dashboard to show, ie. litter box full or it’s trash day
Hi @Andrew_St_Laurent, welcome to the community. Are you using an Android tablet with Fully Kiosk Browser for your dashboard? If so you should be able to do so using the ST community developed Fully Kiosk Browser DTH, which supports loadURL command. Then you can use your virtual switch as the trigger to kickoff the rule, and use this loadURL command with the desired dashboard’s URL to load the specific dashboard.
Edit: Be sure to check out the following post for some tips on how to perform fast client side navigation between SharpTools dashboards:
Thanks, @James. That should work for me.
Wow, I learn so much browsing this forum! Did not realize this DTH was out there.
