Hi my friend, I have tested and getting fun…something is really strange:
1.- As you said, logic seems okey, RULE LOG IS OK, the rule handles cycle counter okey, also the correct IF runs and discard other once control switch is off.
2.- The Issue is for some strange reason after light is set accord the scene, randomly it goes off. For example, cycle switch goes from 1 to 2, scene is RELAX, light goes to RELAX color+level but after a second the light turns off, after the next button push the cycle switch goes from 2 to 3, light goes to NIGHT AMBIENCE and after a second the light turns off. The light turns off RANDOMLY !! ![:thinking: :thinking:](https://community.sharptools.io/images/emoji/twitter/thinking.png?v=12)
50% of the times works okey, the light switches to next cycle and stays, but sometimes it goes off.
3.- I tested the scene dashboard with the same virtual buttons for the scenes, those ones that are pushed in the rule and light works normally (it does not go off), but when the virtual button is pushed inside the rules then this strange issue appears (light goes off randomly).
4.- I tried to change from “PUSH” command to "ON command and I still got the same issue, randomly light off. Also I moved the PUSH/ON command at the end of each THEN section, and I got the same issue
5.- I checked on line with my scene dashboard, when I push the physical button I see the right virtual button flashes in the Sharptools dashboard, light goes on right but then goes off and stays off. I checked in HUE Philips app, and still the same
Conclusion: Pushing virtual scenes buttons works perfectly, but when they are pushed inside the rule lights goes off randomly (50% of the times).
ANY TIPS ? Or I am in the Twiligt Zone …?!?
PD: I tested substituting the virtual buttons by setting light color and level with Sharptools light device settings and I got the same !!!. sometimes light goes off.
