Light tile has no dimming option
I have numerous dimmers in my house. Most are leviton Z Wave and some are Zooz. None of these switches show up on my dashboard with the percentage indicator on the tile. I can only toggle on and off. Am I missing something here? The attached picture shows an example as the shower light and bath light are both controlled via Leviton Z Wave dimmers.
When editing the dashboard, if you tap the ... in the top-right corner of the tile and select Change Layout, do you see an option for Switch Level?
Yes I do. Thank you. That fixed my issue. I appreciate the help.
