What do the Rule Logs say when the device state changes? If the attribute from your trigger changes, you can enable the ‘Debug’ level of logging to see those events even if they don’t match the trigger state.
Life 360 is still working ?..Its not deprecated now because Smartthings going to Matter ? How are you handling 360 my friend, Mine stopped to work month ago as manhy other users…
I stoodup up a hassio supervisor home assistant docker install, and configured the life360 addon. I then connected home assistant and smartthings to sharptools.
