Speaking of thermostats and question marks, why does my Lennox thermostat tile nearly always show a question mark for the set temperature?
Hi David-
Welcome to the community and thanks for posting. My suspicion is that the thermostatSetpoint
attribute is missing or not set.
Would you mind either sharing a screenshot of the device details or sending a PM to @support with the Doc ID of the device?
- Open your SharpTools.io User Page
- Tap the
next to your desired location - Scroll down and tap on your desired device
- Copy and paste (or screenshot) the Capabilities and Attribute Values section
If you want to share the Doc ID with support, you can flip the ‘Advanced’ toggle on in the device details screen, then copy the Doc ID field and send it in a private message to @support.
