Good morning All, So I’m still new at this, but loving it all. I love the resent updates with the music tiles, with that being said is there a way to make the Volume up,down/Light dimmer Scrubber larger? I’m having trouble adjusting the ups and downs. Also is there a way when rearranging the tiles to lock the ones you’ve moved already in place as to stop them from keep moving around? Thank you once again.
Thanks for the feedback and glad to hear you are enjoying things!
For the lighting/volume adjustment, are you referring to the slider similar to that of the following screenshot?
Yes that’s it guessing I got the name wrong
Volume Scrubber was a great description - I just wanted to make sure I understood the request properly. Thanks for the confirmation! I’ve noted the request.
