Is there a technical limitation that prevents sound output?
Curious, is there a technical limitation that prevents sharptools from playing a sounds directly from a dashboard? I mainly use sharptools at work as an alert dashboard with many tablets , and man I’d kill to just be able to have a sound push through the dashboard without needed a third party integration setup. What stops sharptools from just playing a sound itself?
