Is it possible to display images from local Homey in SharpTools?
It’s now possible to access Homey as a local user. Is there any way to get SharpTools to display an image that is fetched locally from Homey?
If I use a link to the local image in SharpTools, the image is not displayed – most likely because you need to be logged in to the local Homey for it to work.
Is there any solution or workaround for this?
Can you tell me more about this? I’m not sure I follow exactly how you are fetching the image or what issues you are running into.
