Curious…
I have an app I would like to launch via the URL Schema…
I have already downloaded the app and found it does not have a URL launcher.
Is anyone aware of another app which might provide a custom launcher URL for an iOS app that doesn’t have one?
I am using “Shortcuts” at the moment, but this takes you out of Kiosk mode…
I use Shortcuts to launch my dash in kiosk mode. Did you put ?kiosk=true on the end of the URL?
Correct. But I am referring to launching an app from within the dashboard. For those small items we can’t automate
For example - you can make a button for myChevrolet app. The launch it using a custom url “myChevrolet://“. Apps launched this way can be exited back to the kiosk dashboard.
But not all apps are create with a custom URL like this.
To work around it, you can use the iOS shortcut app and have the shortcut launch an app. But…
When shortcut loads, it takes over the kiosk mode and you are stuck there.
