We’ve heard you! Many of you shared that nested IF Conditions can sometimes become a tad tricky to decipher. With your valuable insights in mind, we’re thrilled to present the option to vertically stack IF Conditions, enhancing readability and rule design.
While side-by-side IF Conditions remain a preferred choice for simple rules, we recognize their limitations for nested conditions. Hence, we’re giving you the power to choose! The next time you craft or tweak a rule with nested IF Conditions, you’ll be prompted with the option of using the vertical stacking option.
Remember, this setting is specific to each rule. Adjusting your preference is a breeze – just hit the ... icon located at the top-right of the rule editor. Rest assured, your choice will be retained once the rule is saved.
What’s New with Vertical Stacking?
- Improved Readability for Then and Else Blocks
- Gone are the days of squished side-by-side blocks. Welcome a clutter-free space, especially as you delve deeper into nested IF conditions.
- Color-coded Nesting Levels
- At a glance, discern the ‘level’ of your IF Condition. Icons for If, Then, Else, and Condition blocks on the same tier will flaunt the same color, simplifying visual identification.
- Indentations with Color-matched Vertical Bars for Then and Else Blocks
- Elevate the visual structure of your conditions and associated actions, ensuring clarity at every step.
Join us in embracing this feature enhancement and streamline your rule creation experience!
