This question has been asked but mainly regarding ring doorbells. This is more of a fully kiosk question I believe.
I am using an HIKVISION external intercom, which when activated calls the HIK-CONNECT app, now I know sharptools and smart things won’t have a work around.
Currently when in kiosk mode the tablet won’t force open the Hik-Connect app, is there a way that this can if pressed it calls the app for say a minute, let’s you use it then reverts back to the sharptools dashboard?
That’s correct. As there’s no way to integrate the intercom into sharp tools.
Currently when pressed any device with the app installed rings and the app will show a notification, I’m hoping there is a way that this particular app can still show a notification over the kiosk browser, allow me to answer and use it, then after say 2 minutes just close and go back to the kiosk automatically.
I know you can set up a refresh URL on dashboards, I’m hoping there’s a setting the refresh the kiosk after a set period of time after use.
