Integrating my Zmodo camera
@Joel_jones I see. You will need to configure the “Web server” in Blue Iris through wizard first. And then grab the local IP from Blue Iris Web server to use it in SharpTools media tile.
See screenshot below for my BI web server IP and how I can access a particular camera’s MJPEG stream through the link from BI webserver.
_http://192.168.3.199:81/mjpg/garage_
You can also check out the help document in Blue Iris for setting up BI webserver.
