Integrate EZVIZ DP1 peephole camera
@csevgut, what are you looking for in terms of the integration? Do you want to display the video streams on the dashboard? Or have a tile on the dashboard, and it loads the Ezviz app when tapped?
I took a quick log of the DP1C manual but wasn’t able to find any details on the supported protocol. If RTSP is supported, Blue Iris and TinyCam can be used as a NVR to translate the video stream into MJPEG and displayed as a Media tile in the dashboard.
Or if you want to open Ezviz app when a tile is tapped, you can follow the instructions in the post below to identify what intent URL should be used assuming you are using Fully Kiosk Browser to host the dashboard.
