Josh,
Can you please add a few icons related to EVs? I am thinking of an icon for a wallbox, and a car with a cable to indicate it is plugged in. Or any as you see fit.
thanks in advance
Theuns
Josh,
thanks in advance
Theuns
Not an answer to your request, but if you go to the point to where you select the icon, there are tabs system and files.
Going to files allows you to load your own icons for use.
