I have a super tile with 2 icons. The active theme has a shake animation which affects both icons. Is there a way to have 1 icon static and the other animated? I was going to use CSS to target one of the icons to animate shake or remove animation, but I don’t know the CSS code to target animation.
Thanks in advance
Tile Styles apply to the whole SuperTile.
There was some discussion about an approach here:
Thanks Josh. I am using nth item method.
I am trying to figure out if there’s a way to remove the animation from the target icon or would I need to remove all animation from the style and target the icon I want animated?
I suspect either approach could work with the right CSS. I’ll leave that question open to the community…
Hi, I am doing that for my weather supertile, weather icons are animated separately, I am not using the local icons, but gif animations or fixed icons in custom files feature. In my weather supertile there are static icons are animated icons (gifs). I hope this helps…
Can you explain how you got the weather icons are animated separately?
