A humidity monitoring tile that compares indoor and outdoor moisture levels to provide actionable window management recommendations - designed for coastal environments where humidity control is critical.
Overview
Living near the ocean presents a unique challenge: sea air often carries higher humidity and salt spray (maresia) that can increase mold growth and moisture damage inside your home. Opening windows at the wrong time actually makes the problem worse by bringing humid air inside.
Humidity Comparison v2.1 tries to help with this problem by continuously comparing indoor and outdoor humidity levels and telling you exactly when to open or close your windows.
The tile displays both humidity readings side-by-side with a visual flow indicator and provides clear recommendations:
- âOPEN WINDOWSâ - Outdoor air is drier, ventilate now
- âCLOSE WINDOWSâ - Outdoor air is more humid, keep sealed
- âWINDOWS OKâ - Humidity levels are balanced
Perfect for beachfront apartments, coastal homes, or any humid environment where moisture control matters.
Key Features
- Dual Humidity Display - Indoor and outdoor readings shown equally and clearly
- Smart Recommendations - Clear âOPEN/CLOSE/OKâ guidance based on conditions
- Flow Visualization - Animated arrow shows moisture direction
- High Humidity Alerts - Yellow pulsing animation when indoor humidity exceeds 60%
- Gradient Background - Visual indicator of humidity flow direction
- Flexible Data Sources:
- Indoor: Device sensor or SharpTools Variable
- Outdoor: Device sensor or OpenWeatherMap API
- Multiple API Support - OpenWeather 2.5 or 3.0
- Real-time Updates - Instant synchronization with sensor changes
Requirements
Required (choose your setup):
Indoor Humidity Source (one of):
- Device with
relativeHumidityMeasurementcapability - SharpTools Variable containing humidity value (This feature of using a variable is to calculate the average of several devices within the home)
Outdoor Humidity Source (one of):
- Device with
relativeHumidityMeasurementcapability - OpenWeatherMap API (free or paid account)
Compatible Devices:
- SmartThings/Hubitat humidity sensors
- Aqara temperature/humidity sensors
- Zigbee/Z-Wave combo sensors
- Any sensor reporting relative humidity
Optional:
- OpenWeatherMap API key (get free key)
- Location coordinates or City ID
Quick Import
Click the link below to import directly:
Import SharpTools Tile: Humidity Comparison 2.1
Configuration
Step 1: Select Indoor Source
Option A - Use Device:
- Select your indoor humidity sensor
- Leave âUse Variable instead of Device for Indoorâ unchecked
Option B - Use Variable:
- Select your SharpTools Variable containing indoor humidity
- Check âUse Variable instead of Device for Indoorâ
Step 2: Select Outdoor Source
- Select your outdoor humidity sensor
- Leave âUse OpenWeather API for Outdoorâ unchecked
Option B - Use OpenWeather API:
- Check âUse OpenWeather API for Outdoorâ
- Enter your API key
- Set location (City ID or lat,lon coordinates)
- Choose API version (3.0 recommended)
Step 3: Configure Display Options
Refresh Interval:
- Set update frequency in minutes (default: 30 minutes)
- Balances accuracy with API rate limits
Use Gradient Background:
- Enable for visual flow indication
- Gradient direction shows moisture flow
API Settings (if using OpenWeather):
- API Version: Choose â3-0onecallâ (newer) or â2-5multiâ (legacy)
- Location: Enter City ID (e.g., â3703443â for Panama City) or coordinates (e.g., â8.9823,-79.5199â)
Why This Tile Was Created
The Problem: Living in a beachfront apartment in Panama, I noticed mold developing despite cleaning regularly. The issue wasnât lack of ventilation - it was ventilating at the wrong times. Opening windows when outdoor humidity was higher than indoors actually brought in moisture-laden sea air (maresia) that promoted mold growth.
The Solution: This tile continuously monitors both indoor and outdoor humidity and tells you exactly when conditions are right for ventilation. When outdoor air is drier, open up. When itâs more humid outside, keep windows closed and run dehumidifiers instead.
The Result: Significantly reduced mold growth, better indoor air quality, and lower dehumidifier energy costs by only running them when windows should be closed.
How It Works
Visual Indicators:
Arrow Direction:
- â Right Arrow - Indoor humidity higher, open windows to ventilate
- â Left Arrow - Outdoor humidity higher, close windows to seal
Background Gradient (if enabled):
- Left-to-Right - Moisture flowing out (good for ventilation)
- Right-to-Left - Moisture flowing in (keep sealed)
- Neutral Diagonal - Balanced conditions
High Humidity Alert:
- Values pulse yellow when indoor humidity exceeds 60%
- Critical threshold for mold prevention
Recommendations:
- âOPEN WINDOWSâ - Outdoor air is drier, safe to ventilate
- âCLOSE WINDOWSâ - Outdoor air is humid, seal the space
- âWINDOWS OKâ - Levels are balanced
Display Optimization
This tile has been specifically optimized for iOS device screens.
For customization of humidity thresholds, alert behavior, or gradient colors, I recommend using Claude.AI to help modify the configuration values.
Practical Use Cases
Coastal Living:
- Beachfront apartments
- Ocean-view homes
- Areas with salt air (maresia)
- High-humidity climates
Mold Prevention:
- Bathrooms with exterior walls
- Basement moisture control
- Storage areas
- Closets prone to mildew
Energy Optimization:
- Run dehumidifiers only when windows are closed
- Natural ventilation when conditions allow
- Reduce HVAC costs
Configuration Examples
Example 1: Basic Setup (Devices Only)
- Indoor Device: Aqara sensor in the living room
- Outdoor Device: Weather station on balcony
- No API needed
Example 2: API-Based Outdoor
- Indoor Device: SmartThings multipurpose sensor
- Outdoor: OpenWeather API (free tier)
Example 3: Variable + API
- Indoor: SharpTools Variable (averaged from multiple sensors)
- Outdoor: OpenWeather 3.0 One Call API
- Refresh: 15 minutes for precise control
Screenshots
The screenshot shows the tile in âCLOSE WINDOWSâ mode - indoor humidity at 69% with outdoor at 77%. The left-pointing arrow indicates moisture would flow inward if windows were opened. The gradient flows right-to-left reinforcing the visual message.
Resources
GitHub Repository: GitHub - wilsonmarcolin/sharptools-custom-tiles: SharpTools Custom Tiles by Wilson Marcolin & Claude AI
OpenWeather Documentation:
Other Tiles in Collection:
- AC Control - Climate control
- HT Sensor - Dual humidity/temp display
- Weather Information - Comprehensive weather
- UPS Information - Power monitoring
About the Developer
Iâm not a professional developer - Iâm someone who faced a real problem (mold in my coastal apartment) and built a solution. This tile was born from necessity: standard humidity tiles showed me the numbers, but didnât tell me what to DO about them.
The smart recommendations have made a measurable difference in preventing mold and maintaining comfortable indoor conditions.
If you encounter any issues or have suggestions, feel free to share feedback! However, please understand that support may be limited as this is a personal project shared freely with the community.
Apologies in advance for any operational flaws!
License & Disclaimer
MIT License - Free to use, modify, and distribute
USE AT YOUR OWN RISK - This tile provides guidance based on humidity readings but does not account for all factors affecting indoor air quality (temperature, ventilation rate, building materials, etc.). The 60% alert threshold is a general guideline. Consult with professionals for serious mold or air quality issues.
See GitHub repository for complete license and disclaimer.
Version: 2.1 (October 2025)
Authors: Wilson Marcolin & Claude.AI
Tested with: SharpTools Custom Tiles v0.2.1+
Tags: #custom-tile #humidity #ventilation #mold-prevention #coastal-living #smart-home #environmental-monitoring
