Have you tried rebooting the hub, the waiting several minutes for things to calm back down and then try again? Sometimes a reboot can do wonders for a Hubitat hub.
The first entry in the log is the receipt of a new API Key on the Hub which would explain the three events within milliseconds after that not getting posted over successfully. Had you just reauthorized SharpTools before opening up the logs?
