For example, you could use the Virtual Values driver along with Hubitat’s Rule Machine as a proxy for the HSM alert. Maybe have the switch state indicate if an alarm is active and could even use the number to indicate the severity or text to indicate the type of alarm.
Here’s an example post on the Hubitat community where the driver is used to display a Hubitat Rule Machine global variable. The same concepts could be applied here too:
