Hi All,
Has anyone successfully used the Hubitat Beta SDM API integration to be able to expose Nest camera feeds in SharpTools?
Has anyone used the streams from that integration at all? I was following the discussion for a bit, but it sounds like it generates a RTSP stream that only lasts for 5 minutes… and since browsers don’t support RTSP it would have to be used in something else to convert the stream.
