Is there a way I can import my virtual keypad into Sharptools from hubitat?
Thanks
Thanks
Welcome to the community and thanks for posting.
Can you share more details on the virtual keypad? If itβs a community developed device, can you share a link to the relevant thread?
Hopefully that helps.
Hi @Nic_S , just wanted to make sure you are aware of the Tile Security - PIN Protection feature that can be used to achieve the same functionality.
Edit the Dashboard Settings, and set the PIN code
Edit the HSM tiles ( or whatever tiles makes sense to you), and set the security option to PIN Protected
Then when this tile is tapped, it will prompt you for the PIN code
