I’m trying to build a rule to change the thermostat setting with time of day, thermostat temp settings and several presence sensors.
I have the trigger set to thermostat changes and is above 77 degrees with the flow set at the time between 10 AM and 5 PM and person 1 is present when all conditions are met. This works fine but I want to add additional presence sensors to the mix. If I leave it to all conditions are met the rule will only fire if all sensors are present and if I change the “all” to “or” the rule would fire if no one is present.
Is there a way make this work without building a rule for each presence sensor?
