Hi
I have created a simple display for the Lounge.
The Time top right of Dashboard and is not utilising the space well and has a lot of dead space.
I cannot find the way to increase or even change the font?
Hi
@Michael_Horton, you can use the Custom CSS feature within the Theme Editor to adjust clock’s font size.
.tile.clock .time { font-size: 1.8em; } .date { font-size: 2em; }
@kampto also puts together a WIKI CSS post below which has the CSS style scripts contributed by other community users.
AWESOME!!! Thanks had to set an 8em to get to the right size
How do I make the day of the week name larger and centered?
You could use a Super Tile to build a ‘clock’ tile with date and time information in whatever format you’d like. This gives you full control over the positioning, content, and sizing of items.
There’s even a ‘Custom’ format at the bottom of the Date/Time Format list where you can manually enter your desired format.
Thanks for the suggestion, I probably should have thought of that myself since I am using several super tiles already. As a general question, is there an easy way to see the field names and values from inside a super tile? For example, if i wanted to select the Style based on the day of the week or month.
I don’t understand the question.
Super Tile styles can be configured based on the Variable and Thing values associated with that particular Super Tile, but they can’t be configured based on date/time values.
As an example… Is it possible to have the Style switch from “ClockStyleAM” to “ClockStylePM”? Would I have to use a “Rule” to set a variable that I can test in the Style selection?
No, you can’t use date/time values for styles, as mentioned above.
You can use Variable and Thing values that are included within your Super Tile for styling, so in theory, you could create an $isMorning variable and flip it true/false based on the time of the day. It would need to be included within your Super Tile, but I suppose you could either drag it visibly off the Super Tile partially or bind it to an icon as blank.
