Hi,
Legrand does not support Smartthings so I am not able to add Legrand switch to the SharpTools.
Are there any way to add Legrand switch to SharpTool?
Hi,
Unfortunately, you’re going to have to get the switches added to a hub that SharpTools works with.
I do not use LeGrand switches, but Home Assistant reportedly has an integration that allows it to work with the switches via their API. I don’t know much about it, but it may be worth you exploring:
