Homey Pro "thing" problem
Hello, in light of the smartthings API changes coming, I am trying to migrate everything over to Homey Pro. I have authorized, selected and synced Homey in my Sharptools account several times and can see everything that I have in Homey on sharptools. The device I am having trouble with is a Meross garage door opener. The device works properly in Homey but when I try to create a tile in sharptools to operate it the only attribute that is available, (other than none), is “garage door alarm”, with value “false” and commands “set homey boolean”. There is no option for an action to open or close. I don’t know if its relevant or not, but in the “Things” drop down, all of the smartthings things have green check marks and none of the Homey things have the green check marks. I must be doing something wrong, would anyone know what that might be? Thank you in advance for any help!
Can you share more details about how you have the device connected into Homey? I presume it’s either using the official Meross integration or the Meross community integration by Bence Palatin?
I have a Meross Garage Door Opener, so I’d like to try to connect it to my Homey and see if I can reproduce the issue.
Hi Josh, I couldnt find support for the Meross garage door opener in the official Meross app so I am using the Meross community integration by Bence Palatin.
Hi Josh, did you have any luck reproducing the problem with your Meross opener?
Hi Josh, I created a flow in homey for the garage door, then downloaded/installed your custom tile script for homey and was able to make the Meross garage door opener operate successfully from the shaptools dashboard.
