Several of the custom commands in the community device handler for the WD200+ do not show as commands in ShareTools. These commands are available in webcore, so I am not sure what the difference is, but I am looking to migrate to here.
Is the device currently using a Groovy DTH?
In the next-gen SmartThings API, the device must expose custom commands/attributes under a custom capability in order for them to show up in the SmartThings APIs. Most new Edge Drivers are implementing custom capabilities, but many legacy Groovy DTHs have not.
Yes this is a groovy DTH. I am not sure what is going to happen when it goes to EDGE yet.
That’s likely the problem. The command you’re looking for is probably a custom command, but is not implemented in a custom capability since it’s a Groovy DTH.
Are you using the custom DTH by Kevin (krlaframboise)? He mentioned this in another thread:
Ah, Ill add it to the list of things coming but not ready for EDGE day 1.
