I was also thinking of utilizing the Custom Light Dimmer by @Dinis_Carvalho and updating it with the appropriate currentTiltPosition(), setTiltPosition() commands in place of the getDimLevel(), DimLevel() commands.
Thoughts…feasible or not?
@Dinis_Carvalho - any arguments, if possible to adhere to the vent damper custom time creation?
README
Create a SmartThings 'Personal Access Token' with access to devices and use it
for the 'token' setting in the tile.
https://account.smartthings.com/tokens
Light dimmer created by Dinis Carvalho, inspired by Joshua's scenes tile:
https://github.com/joshualyon/custom-tile-demos/tree/main/smartthings-scenes/
<!-- Do not edit below -->
<script type="application/json" id="tile-settings">
"schema": "0.1.0",
"settings": [
{"type": "STRING", "label": "Token", "name": "token"},
{"name": "DeviceID1", "label": "Device ID 1", "type": "STRING"},
{"name": "DeviceID2", "label": "Device ID 2", "type": "STRING"},
{"name": "DeviceID3", "label": "Device ID 3", "type": "STRING"},
{"name": "DeviceID4", "label": "Device ID 4", "type": "STRING"},
{"name": "DeviceID5", "label": "Device ID 5", "type": "STRING"}
"name": "Light Dimmer"
</script>
<!-- Do not edit above -->
<!-- Styles -->
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/noUiSlider/15.5.1/nouislider.css" integrity="sha512-MKxcSu/LDtbIYHBNAWUQwfB3iVoG9xeMCm32QV5hZ/9lFaQZJVaXfz9aFa0IZExWzCpm7OWvp9zq9gVip/nLMg==" crossorigin="anonymous" referrerpolicy="no-referrer">
<style>
.main-content {
display: flex;
align-items: center;
justify-content: center;
position: fixed;
top: 0;
left: 0;
width: 100%;
height: 100%;
padding-top: 10px;
.slider-wrapper {
width: 70%;
height: 80%;
border-radius: 8px;
.noUi-target {
background-color: rgb(255 255 255 / 30%);
border: 0;
box-shadow: none;
backdrop-filter: blur(8px);
border-radius: 8px;
.noUi-connect {
background: rgb(255 255 255 / 30%);
border-radius: 8px;
.noUi-handle {
opacity: 0;
width: 90px !important;
height: 50% !important;
margin: 0 !important;
right: 0 !important;
</style>
<!-- Scripts -->
<script src="https://cdnjs.cloudflare.com/ajax/libs/noUiSlider/15.5.1/nouislider.min.js" integrity="sha512-T5Bneq9hePRO8JR0S/0lQ7gdW+ceLThvC80UjwkMRz+8q+4DARVZ4dqKoyENC7FcYresjfJ6ubaOgIE35irf4w==" crossorigin="anonymous" referrerpolicy="no-referrer"></script>
<script src="https://cdn.sharptools.io/js/custom-tiles.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/axios/0.21.1/axios.min.js"></script>
<script>
var content = document.getElementById("mainContent");
var patToken = null;
var devices = [];
var baseUrl = "https://api.smartthings.com/v1/devices";
function initSlider() {
slider = document.querySelector(".slider-wrapper");
noUiSlider.create(slider, {
start: 0,
connect: "lower",
direction: 'rtl',
orientation: 'vertical',
range: {
'min': 0,
'max': 100
slider.noUiSlider.on('change', function () {
var value = parseInt(slider.noUiSlider.get());
console.log("Slider changed to: " + value);
setDimLevel(value);
function setSlider(val) {
slider.noUiSlider.set(val);
function getDimLevel() {
var dimLevel = 0;
axios.get(baseUrl + '/' + devices[0] + '/status', getAxiosConfig()).then(function(response) {
console.log('Get dim level response status', response.status);
if(response.data.components.main.switchLevel !== undefined) {
dimLevel = response.data.components.main.switchLevel.level.value;
setSlider(dimLevel);
function setDimLevel(value) {
var data = '{"commands": [{"component": "main", "capability": "switchLevel", "command": "setLevel", "arguments": ['+value+']}]}';
for(var i=0; i<devices.length; i++) {
axios.post(baseUrl + '/' + devices[i] + '/commands', data, getAxiosConfig()).then(function(response) {
console.log('Set dim level response status', response.status);
function getAxiosConfig(){
return { "headers": { "Authorization": "Bearer " + patToken } }
stio.ready((data)=>{
console.log("Starting Light Dimmer [shortyyy]");
console.log("stio library is ready with token", data.settings.token);
if(data.settings.token == null || data.settings.DeviceID1 == null){
console.log("Please configure the authorization token and at least 1 device");
return;
else{
patToken = data.settings.token;
for(var i=1; i<=5; i++) {
if(data.settings["DeviceID"+i] !== null) {
devices.push(data.settings["DeviceID"+i]);
console.log("device IDs", devices);
initSlider();
getDimLevel();
setInterval(getDimLevel, 30000);
</script>
<!-- HTML -->
<div class="main-content" id="mainContent">
<div class="slider-wrapper"></div>
</div>
