Help with Variable tile Changing when one device active
It’s not natively supported as a feature you can just toggle on Dashboard tiles, but you can accomplish it using SharpTools Rules to aggregate the status of multiple devices into a variable… then use that variable in place of your Dashboard tile configured to link to your desired dashboard.
Here’s a few posts showing the concepts:
References:
