Help with simple rule
I am trying to make a simple rule to refresh my Honeywell thermostats… I put in a virtual switch to be able to trigger it on the dashboard in case something gets messed up… I have the delay set for only 30 seconds right now so I can easily see the logs. The virtual switch triggers the rule… however the loop is not working at all. Im sure I messed something up, but it is so simple and I dont see where it could be going wrong. Thanks in advance for any help!
ok figure it out… there needs to be a delay before setting the variable back to false… I am using a 5 second delay and now it is working fine.
Thanks for the update - glad the ‘wait’ action got things working for you!
I saw your post in the SmartThings community and replied there as well. :smiley:
Yes, I saw that thank you… not sure the issue, but it is working fine with the delay. Thank you!
