I have a master rule which changes this variable to true and fires accurately every time.
This ‘child’ rule should be a looping rule based on the variable change until conditions are not met. I watch the variable change to true in the resource section based on the master rule but the variable has not changed to false based on the rule triggered by the variable.
I can manually trigger the rule from the dashboard. All If conditions are true.
The rule is not firing when the variable changes to true. The variable changed to true at 0742. It is now 0752 and the variable has not changed to false.
@Terri , what is the rule id of this rule? (You can find it from the URL when editing this rule.) I can look up in the log if there was any error. Meanwhile, you may want to add a couple email notifications before the IF condition and after the Voice Monkey action to help you troubleshoot.
I am having a lot of issues with rules based on variable changes.
I have one set up that does nothing but send an sms when the variable changes and I rarely get the sms. Other rules triggered by variable changes execute as long as the variable IS true/fale not just when is changes to true/false. Maybe this is related.
Thanks for info and I have replied my findings in the PM. I noticed both rules are some how complicated with the same variables used in multiple rules which may cause race condition or undesired interference if the logic is not designed carefully.
For the SMS notification, it can be something different. I have moved all my notifications from SMS to Pushover because I’ve found Pushover more useful, more reliable and just as fast, if not faster. Cell carriers’ SPAM detector tends to block SMS messages if the messages are alike and sent multiple times within a short period (how the SPAM policy works is a basically a black box.) and it is up to them to determine how long the message will remain blocked. Ex: if you send SMS messages - “security alert” a few times within a few minutes, it’s likely to be in the carrier’s black list for a unknown period.
