So recently got 2 switchbot roller shades implemented into HA via bluetooth and then added to sharptools. I can open close them but cant seem to figure out how to simply set the position to say 40 or 50. Using the window shade tile. Was wandering how to go about doing so bc i have tried a few things with no luck. Or maybe theres limitation there? *Also noticed the 2 swicthbot blind tilts are the same way, can open close but cant set postion. Have 2 of those as well.
I’m not sure what attributes or commands that particular device exposes, but you might try the Vertical Range Slider custom tile:
I had seen your suggestion previous to your reply and that didnt work either. i did figure it out as I manily use Hubitat. I bridged the devices into Hubitat and then had to create a virtual shade and the mirror app to mimic state changes. Added the virtual shade to Sharptools and it now lets me set the shade to any desired postion! ![]()
