Can someone tell me why my dashboard keeps logging out and I get message that says “Google Log in Disabled”? I end up having to log in with the phone link and it will work for awhile until it logs out again.
For a while I used a custom user agent like the blue part of your screenshot says to work around the Google login thing, but I usually just login with my phone number now.
I had an issue on one of my tablets and was getting logged out and I ended up factory resetting and reinstalling things on the tablet as I couldn’t figure out what was causing it.
Thanks for the response. I will try resetting as a last resort. Hoping staff members will have some more input as to why I keep getting logged out. I seem to spend so much time fixing things such as this and devices dropping off etc. I’d like to spend more time working on scripts and improving my automations. I actually stepped away from it for about 3 months then started repairing everything when I had time during the holidays. Now I’m back to zigbee devices dropping off one by one!!
Hi @Robert_Figueroa thanks for sending a PM! If you don’t mind, I’ll respond here in the main thread so other people who find this topic can benefit from the discussion.
Google Login is disabled (by Google) if you attempt to login via a mobile app which uses a webview. It looks like you are using Fully Kiosk based on your screenshot and the message shown in the blue info box at the bottom.
Most people tend to link a secondary login type like a phone like you have. Since you are on Fully Kiosk Browser, you could manually change the User Agent to emulate an iPad or other supported browser/device and use Google login. Linking another login type is our primary recommendation though.
As to why you are getting logged out, there’s two common reasons that may or may not apply here. Fully Kiosk Browser does have a number of settings around data management that can cause login sessions to get cleared. Most of them are under the Web Auto Reload settings section in Fully Kiosk Browser and should be turned off. (Similarly, third party ‘app optimization’ apps can cause the data or cache on Fully Kiosk Browser to get cleared and should be disabled) The other common thing is making changes to your login accounts - for example, linking new login types or resetting your password can cause your existing login sessions to get invalidated.
I need a little direction on this. Every time I try logging on I get logged off if not the same day the next day. I haven’t been able to enjoy Sharptools because of it, really annoying. Is there any other advise you have on this issue? I tried messing with the settings like you said but it did not help. I also did not see any topics similar to this on the forum. Any help appreciated
What type of device is this on? And do you have SharpTools running on any other devices and do they stay logged in?
Fire Tablet 7 and I do not have any other devices logged in. I do have an iPad mini that it is installed on but I checked and it was logged out.
What generation Fire 7 is it? The Fire 7 tends to be a fairly underpowered device – even more so with the older versions.
I mentioned a few potential reasons for getting logged out in my reply above. The two main things are basically the session data getting cleared from the tablet or major changes to your account (which causes invalidation of sessions).
While the most common cause for session data getting cleared out is the accidental activation of settings in Fully Kiosk Browser that clear the cache or the running of ‘app optimization’ apps, it’s also possible that the device is running out of resources and the OS is attempting to reclaim them. You could try doing a factory reset of the tablet to start with a clean slate, then install Fully Kiosk Browser directly from the FKB website and configure it with minimal settings changes.
@Robert_Figueroa I once had the Google logout issue, and I vaguely remember I had side loaded Google Play Store and services at that time. I ended up factory reset the tablet and use FireOS version Fully Kiosk Browser after all, and the issue never happened since.
