Gauge (on Supertile) not working on Surface Go
Hope there is a solution for this. I added a Gauge on a Supertile that controls parts of the auto shadow controls for the house. The Gauge is linked to a variable that contains the temperature at which the window shutters will perform a specific action. The Gauge is only linked to the variable and has no other function, other than display and the ability for the variable to be changed.
On the dashboard everything works fine on my computer in Edge as well as Chrome. On my Samsung phone it also works fine. The house dashboard is a Microsoft Surface Go (the small surface thingy). On this device, the Gauge is dimmed and not functional. I tried it on Edge and Chrome, same result. So it must be something within the OS that blocks the Gauge from working.
Any suggestions? I have since implemented a plain number display that will cycle through the range as a work-around, but if there is a solution, I would really like to switch back to the Gauge.
A post was split to a new topic: Gauge Custom Tile Not Working
Maybe you could share a screenshot of what you’re seeing?
Do you mean it visually renders the gauge and it’s properly reflecting the value, but it’s grayed out and you can’t control it?
