I’m in the process of removing MyQ Lite for the SmartThings groovy EOL. I have a Zooz Zen 16 all setup along with a SmartThings multipurpose sensor on the door. I’m having trouble writing the logic to control the door like MyQ Lite did. It tried within SmartThings to make routines and I’m getting auto opens and closed based on if I used the physical buttons or the app. This means I’m missing something based on the status of either the Zen16, sensor, and/or virtual garage door switch. This is where I think SharpTools would be the better option.
Has anyone written a rule that accomplishes most of what MyQ does in SharpTools?
I basically use it to automate the door to ensure it’s closed at night, when we leave and open when my wife comes home.
I installed it tonight, created the automations and it appears to work well. However, and it is a big however, after the garage closes, it immediately does a door open. The device updates to closed and then goes right to open.
I am using a wife relay for the button push and a smarthings contact sensor for the open or closed.
@Scott_Ross, are you using the Zooz Zen? If so, you need to configure the switch. I’ve attached a screen shot of what the first few settings show for me. Mine is working exactly as I expect it to.
