Garage Door "closing"
I have a RatGdo connected to Home Assistant that’s then being pulled into Sharptools. It’s worked great for years, but recently it started not going from “closing” to “closed” about 50% of the time.
The status is always correct within home assistant. The other status transitions seem to work fine, like closed>opening>open. It’s only closing>closed that seems to be getting stuck about half the time.
Edit: Sent Doc ID to support@sharptools.com
Has something changed with the device driver, the device firmware, or the Home Assistant software versions recently that might coincide with the timing of the issues?
For internal diagnostic purposes, we have an event cache that temporarily holds recent events so I replied to your email with a snapshot of those events.
It looks like the device tends to spew events for the intermediary states of closing and opening. I suspect that those events are coming in so fast across near the end of the closingclosed transition that the system is unable to determine which one is the newest / last one in.
Take for example, the 12:37 transition from open to closed just recently today. The device emitted 25 closing events and it looks like the final set of 3-4 closing events and the closed event all came in within the same second.
Date Time TZ attribute value
10/3/25 12:37:08.912 PM UTC-5 door closing
10/3/25 12:37:08.912 PM UTC-5 door closed
10/3/25 12:37:08.855 PM UTC-5 door closing
10/3/25 12:37:05.054 PM UTC-5 door closing
10/3/25 12:37:04.262 PM UTC-5 door closing
10/3/25 12:37:02.748 PM UTC-5 door closing
10/3/25 12:37:01.797 PM UTC-5 door closing
10/3/25 12:37:00.914 PM UTC-5 door closing
10/3/25 12:37:00.420 PM UTC-5 door closing
10/3/25 12:36:59.970 PM UTC-5 door closing
10/3/25 12:36:59.403 PM UTC-5 door closing
10/3/25 12:36:58.892 PM UTC-5 door closing
10/3/25 12:36:58.505 PM UTC-5 door closing
10/3/25 12:36:57.891 PM UTC-5 door closing
10/3/25 12:36:57.385 PM UTC-5 door closing
10/3/25 12:36:56.882 PM UTC-5 door closing
10/3/25 12:36:56.384 PM UTC-5 door closing
10/3/25 12:36:55.869 PM UTC-5 door closing
10/3/25 12:36:55.369 PM UTC-5 door closing
10/3/25 12:36:54.884 PM UTC-5 door closing
10/3/25 11:56:59.117 AM UTC-5 door open
