I am using fully kiosk, and I put the ?kiosk=true which works 100% when select the option to go to home screen. But, after the tablet sleeps, then wakes on motion, it is no longer in kiosk mode.
@Armand_Welsh, can you provide a bit more information about your Fully Kiosk Browserâs settings? Did you include the ?kiosk=true parameter in the Start URL? and does this happens no matter if youâve navigated to other dashboard/pages before it sleeps?
This is definitely not expected behavior so Iâd imagine some settings in FKB might have caused this.
Happy to. As stated in my post, ?kiosk=true is there, and that works 100% of the time, when I navigate to the start page (page swiping from left to expose fullyâs menu, and select Go Start Page.
How would you like me to send my configuration?
I think James was just asking what settings have been changed in Fully Kiosk Browser - or for that matter, any automations or rules that might be interacting with Fully Kiosk Browser.
So, I have isolated the specific scenario. if I swipe down to force a refresh (and I do have fully kiosk force a refresh on certain conditions), then the refreshed page load with kiosk mode turned off.
so, to reproduce, go to start page, then navigate to another dashboard, force a fresh, and post-refresh, the dashboard is no longer in kiosk mode.
I just turned the address bar on, and apparently the query parameters are removed when navigating to another dashboard. The kiosk mode remains enabled, until you refresh the page, which renders w/o the query parameters, since it was removed from address. I am guessing you are likely using a router to push the address onto the address bar, rather than actually navigating to the new URL, since this appears to be a Single Page Application. So the fix should be simple⌠when pushing new addresses into the browserâs history for the router feature, just append any query parameters to the pushed url.
When you manually add the ?kiosk=true parameter to the URL, it tells the SharpTools.io web app to enter kiosk mode. It stays in that mode as you navigate around unless itâs explicitly told to exit or when hitting a non-dashboard page. For example, if you use the Dashboard Tiles or hyperlink to another dashboard, it stays in kiosk mode. As a counter example, if you hyperlink to the list of dashboards, youâll automatically be exited from kiosk mode. Similarly, if you manually hyperlink to another dashboard with ?exitKiosk=true, it will exit kiosk mode.
When you use the Dashboard tiles, you are routed to the other dashboardâs URL, but it does not attempt to retain any manually added query parameters.
So once youâre on another URL which does not have the ?kiosk=true, if you refresh the page, itâs equivalent to reloading the web app and since the kiosk mode startup flag doesnât exist on the page, then you donât get entered into kiosk mode.
Can you help me better understand these scenarios? Why is the page being manually refreshed or being refreshed through an automation? Why not reload the start URL instead?
I would think that this behavior is counter-intuitive. When I enter kiosk mode, and I use the âDashboardâ tiles to navigate between dashboards, and I then issue a ârefreshâ of the page, I would expect the refresh to re-render the page as-displayed prior to the refresh â but with new data.
The reason for this is when network issues occur, the links break, and web-sockets are severed. I donât want to have to reset back to the start page, I just want the page I currently have visible to render correctly, so the page is re-drawn with functional tiles.
I donât know if you are using web-sockets, or polling the server to updates, but when the wifi drops out, this breaks, and tablets are not the most reliable devices for staying connected to wifi. Now that I know it is the refresh, I can go back to the âWeb Auto Reloadâ options and turn off all the auto-reload options that are turned on. But still, if I cannot use pull-to-refresh, since this exits kiosk mode, I will need to disable that feature too.
This seems less than ideal, but I will make those changes to my settings for now, and try to explain to my wife how to bring up the start page when things stop working.
Bumping this thread, as itâs what Iâm currently struggling with. I enable kiosk mode via the âFullscreenâ option, after navigating to my start URL in FK. Everything works as it should for a while, but then randomly Iâll notice that kiosk and/or fullscreen mode get kicked out and it goes back to normal sized browser window. Do I need to append the âkioskâ string to my URL, even when using the âfullscreenâ option?
@Jordan_Welker, yes, you will to add ?kiosk=true to the end of the url in FKBâs start URL, so it doesnât exit the kiosk mode when tapping Go to Start URL, or auto reload start URL if configured so in FKB.
Oh ok, maybe my issue is related to the auto-reloading.
Certainly could be. In general, you probably donât need autoreload features in Fully Kiosk Browser enabled. The page can also reload if Fully Kiosk Browser crashes and automatically recovers.
I just put together a help desk article covering this topic â please let me know if you feel like anything is missing from it:
I have my dash url appended with the ?kiosk=true and I find that whenever I use a tile that launches an app using its intent (I have these for Sonos, CCTV and EvoHome heating), that it comes out of kiosk mode. When Iâm finished in the app, the only way out is to click the back key on the lower menu bar of my Fire HD 10s. I have to then even click the icon to put it in fullscreen or swipe right and use the fully goto start url button. Iâll take a look at that article - maybe thereâs a better way.
